GA3 Hue and Saturation/OPC
Discussion in 'LCD & LED LCD TVs Forum' started by richjthorpe, Mar 15, 2005.
Tags:
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi all,
    Can anyone tell me what the Hue and Saturation levels change ? When playing around I didn't notice much although I did only change a couple. Are there any tests cards to change these values at all ?
    Also, the OPC. I think it's a good idea if only it worked. If there are any Sharp technicians/analysts/R&D around here, why not put a low, low-mid, mid, mid-high and high options on this to cater for all users taste. At the moment it seems to be set to high and goes too dark when the lights are turned off/low.
    Richie.
  2. LcdGuru
    LcdGuru
    I believe hue only works with NTSC (never twice the same color)
    Saturation is colour gain - if you turn it right down you get black and white.
    My OPC seems unstable at low light levels - the screen keeps stepping up and down in brightness so I don't use it. Needs more hysteresis & damping in the software. Some user options for the OPC would have been nice - eg. max, min and damping.
  3. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    I thought this was the 'Value' options. If you turn all of these down, don't you get B&W also ?
