GA P31-DS3L Dreams Shattered
Discussion in 'Computer Components' started by buildrebuild, Jan 9, 2008.
  1. buildrebuild
    buildrebuild
    I have been reading loads of reviews on the Gigabyte GA P31-DS3L and was about to plump for one as it fitted my price range and requirements perfectly...Until I discovered it didn't have Firewire.Aaaaagghhhh.
    I thought I nrealy had my computer sorted. It costs about £20 or more to add PCI Firewire ports.
    Are there any other recommendations which include Firewire, are stable, relatively cool etc and are within the price range of £45-£50?
    Clint
    What about this http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=2324
    Do you think there would be any compatability problems?
  2. jetinder
    jetinder
    Sep 16, 2006
    1,594
    63
    +139
    Chill out.
    You have a good motherboard with 3 spare PCI slots, unless you use all 3 PCI slots you can pick up a firewire card cheaply and use that in the GA P31.
