G2 Sony A normal question, sorry
Discussion in 'Projectors, Screens & Video Processors' started by etotore, Nov 23, 2003.
  1. etotore
    etotore
    when I have the PJ on with no source.
    I see a hint of light in the green tube.
    Blue and Red are "off".
    PJ I have is sony G-70
    I remember reading about how to adjust the voltage down but I cant find it again.
    So do anyone have the way to do it???
    And the time to answer???
    Thanx
    Tormod
  2. cosmic023
    cosmic023
    Feb 15, 2003
    1,369
    48
    Somerset
    +88
    Hi Tormod,
    Not sure if this link helps ??
    As the AVS forum is closed for now, that's where you'd find a lot of answers...........i'm sure someone like Chris, Gordon or Roland could help you out.
    Cosmic023
  3. etotore
    etotore
    Thanx, but I have downloaded both of them.
    But this one I quess is stated in the service manual.
    So I'm still looking.
    Tormod
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I wouldn't worry if it is just tiny glow, if it illuminates the screen with all lights off then it probably needs adjusting but your colour balance will go.
    G2 is behind the Bais setting its a toggle through the menus. Dam clever Japs what's wrong with a simple knob you turn.
  5. etotore
    etotore
    Thanx, but not in my SW.
    It is not there!! :(
    BR
    Tormod
