G2 Adjustment on a Barco Data 801s
Discussion in 'Projectors, Screens & Video Processors' started by pegFACE, Nov 15, 2001.
Thread Status:
Not open for further replies.
  1. pegFACE
    pegFACE
    Ahoy,
    Came to be adjusting the G2 dials after replaceing the focus module, and i was wondering :
    the light is supposed to go off yes and then come back on?
    I got the red and the green to do this, but could only get the blue to go off and stay off, or stay on :(
    Just wondering about how its supposed to be
    also when i start the Barco up, all the G2 lights go off and then come back on...
    in setting the G2 i assume its will auto set the contrast of each colour?
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    In the G2 adjustment menu all three light should just be off. they should idealy be off having turned the dial the same way.
    When the picture is running the LED's should flash like a cheap disco.
    Does it work?????
    ie stopped arcing ???
Thread Status:
