MuFu
Established Member
I thought since there is currently no mention of these subs on the MJA website I'd post the info they sent me here. Please excuse the marketing BS (hehe) and any spelling mistakes etc; I just quickly OCR'd the leaflets this morning.
Reference 100
SPECIFICATIONS:
120watt DC-coupled Bi-Polar Amplifier *
Speaker and line level inputs with Gain Control Range 80dB *
Neutrik Speakon connector (Gold Plated) (High level 100k ohm) *
Unbalanced RCA (phono)(Gold Plated) (Low level 10k ohm) *
Sophisticated crossover circuit - variable increments between 30Hz and 120Hz *
Straight-through LFE Bypass filter switch * Phase Control infinitely adjustable between 0° and 180° *
Frequency response 13hz to 120hz * A.S.P. (Automatic Speaker Protection) *
D.A.M.P. (Digitally Accurate Microprocessor) *
Specially designed cabinet structure, volume, and configuration made from inert 18 & 30mm MDF *
Digital Display with power output meter and frequency setting * Switched fused IEC mains input socket *
200mm (8") Ultra Long-throw Driver with heavy duty pressed chassis & magnet *
3 year manufacturers return to base warranty * Dimensions (WxHxD ) 278mm X 332mm X 278mm *
Weight 10.5kg (23.1 Ibs) *
Black Satin finish as standard with Real Wood Veneer finish an option at extra cost.
£349.00 (black or silver)
£399.00 (wood veneers)
Reference 150
SPECIFICATIONS:
150watt DC-coupled Bi-Polar Amplifier *
Neutrik Speakon connectors (Gold Plated) (High level 100k ohm) *
Balanced (XLR) connectors (Gold Plated) (Low level 10k ohm) *
Unbalanced RCA (phono)(Gold Plated) & 3.5mm PC connectors (Low level 10k ohm) *
270mm (10") Ultra Long-throw Driver with heavy duty pressed chassis & magnet *
3 year manufacturers return to base warranty * Dimensions (WxHxD ) 300mm X 358mm X 290mm *
Weight 14.65kg (32.3 Ibs) *
£549.00 (black/silver)
£629.00 (wood veneers)
Hope this is useful for some people.
MuFu.
Edit - Gawd... this looks like an ad, doesn't it?! Mods if you want to change anything go right ahead...
Edit - Marketing BS removed, heh.
Reference 100
SPECIFICATIONS:
Reference 150
SPECIFICATIONS:
MuFu.
