FX66 Remote
Discussion in 'Televisions' started by paulsheerin, Jan 3, 2003.
  1. paulsheerin
    paulsheerin
    Is it possible to assign number buttons on the remote to the AV channels?
    eg: pressing No 7 = AV1 and so on.
  2. TommyP
    TommyP
    Nov 7, 2002
    63
    Maidenhead, Berkshire
    Don't think so but if it is true it would be seriously useful.
  3. simon1
    simon1
    Jul 7, 2001
    917
    28
    Teesside
    +58
    I would think it is possible, although it's nothing to do with the remote.
    I had the FX65 for a short while and used channel 8 for AV2 and channel 0 for AV1.
    Go to the manual tune option, choose a channel no and you can then pick which AV input to go with that particular channel.
