Question fx or bronze 1 for rears? monitor audio (5.1 set up)
Discussion in 'Home Cinema Buying & Building' started by wakkaday, Jun 17, 2018.
  1. wakkaday
    wakkaday
    Jul 13, 2010
    32
    i currently have on order/or recieved...
    monitor audio -
    bronze centre speaker
    bronze 1 (front wall mounted)
    bronze fx ( rear wall mounted/side wall)
    will get sub at later stage, maybe monitor audio?
    is it worth sticking the 1's at the back and getting the bronze 2 for the front channels?
    thanks
