FV and Lip-sync
Discussion in 'Plasma TVs Forum' started by Brooktop, May 13, 2005.
  1. Brooktop
    Brooktop
    Feb 2, 2005
    2,106
    Nottingham
    +94
    I have a PW6 and have never noticed any lip-synch problems on DVDs and FV is fine most of the time, but every now and again I get probs on FV - particularly ITV2. As this is intermittent, I assume it's to do with the broadcast.
    I have a Yamaha amp but am not sure if it has delay, but I suppose I'd have to be forever fiddling with it.
    Don't suppose anyone knows of a solution?
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    if you amp does have delay you may be able to find a setting that sorts out the lipsync without causing the problem in revers when yuo don't have it. Example, I leave mine on 60 or 70 delay and it never needs changing.
    I don't know but I wonder if it may be an issue with ITV2 because it is higher quality broadcast....I noticed last night that recording the Bill on itv2 took up 7% sky+ memory as opposed to only 4% on ITV1.
