Future proofed HighDef data/AV streaming
DarkKnight
Hi all,
I'm planning ahead for a new home I'm buying and wanted to lay down a home network to stream AV content around the house. This is likely to be via Media server which can send and receive data, audio, voice and IR.
However, I would like this future proofed to handle High Definition content when it eventually hits the UK.
Can CAT5E handle this ?
If not what type of cabling should I consider ?
Also, would I need any special type of hub/switch or plug convertors to handle this ?
(Apols if this question has been asked before, but I couldn't find anything!)
stripe
Yes Cat5E will handle it, but if you really want to future proof yourself, get Cat6 which is guaranteed to do Gb and a obviously you'll want to get a Gb Switch and NIC's.
However to stream HD material you will need hi-end PC's to get any kind of results out of it.
stripe
Cat6 really is just an updated version on 5E but it is guaranteed to do what it claims, you'll probably not notice any difference.
