Fussy Text when running PC
Discussion in 'Plasma TVs Forum' started by Deanooo, Jul 26, 2005.
  1. Deanooo
    Deanooo
    Hi all,
    I have connected my Panny 42PE30B upto my PC via the 15pin connection on the front, all goes well but the text is very fuzzy??
    Is it the graphic card or some settings I can play with??
    If it is the Card could anyone recommend one they us as I really want to utilise the Screen for PC use??
    Thanks alot in advance
  2. jblandford
    jblandford
    Mar 4, 2002
    46
    You need to drive the display in its native resolution. :thumbsup:
  3. benwong
    benwong
    Due to the nature of the connection you're using, text on such a large screen with always have a certain fuzzyness to it.
    If the screen has a DVI input port, use that instead.
    Ben
  4. Deanooo
    Deanooo
    cheers for the advice.
    would you call text that is eligable from 5 foot fuzzy?? As this is the case I have to be very close to the screen to read it??
  5. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    what resolution are you currently running at? It may be wise to increase the text size for web-browsing etc if you have trouble reading it at less than 10'
  6. Deanooo
    Deanooo
    I have tried to run it at various different resolutions
    1280x1024
    1280x768
    1024x768
    Obviously the text becomes more legible the lower the resolution but the text is still fuzzy and not as clear as it is on my monitor.
    Would a higher spec card help this or would I be wasting my money, I currently run a Nvidia Geforce FX5200 128Mg??
  7. codlord
    codlord
    May 17, 2002
    283
    Portsmouth, UK
    The problem is not the graphics card but the resolution of the plasma. I think your plasma has a native res of 852x480 which means any higher and you will lose some detail. A lot of modern graphics cards/drivers have the native res as a res option so this is your best bet for super-clear graphics. However, as you probably know this is not actually much use for a lot of applications/web browsing - just not enough screen space.
    Depends what you intend to do with it - personally I use native res most of the time as I just use it as an mp3 jukebox and that res is fine for running winamp/visulisations etc. If I want to web browse I switch to 1024x768. I don't really use the PC on the pasma for anything else. Some (nvidia at least) drivers allow automatic res switching, so when you run a certain application you can have the res change automatically etc.
    Assuming you are running windows you can tweak font size and appearance settings so that text is more readable.
  8. Rambles
    Rambles
    Jul 14, 2004
    8,146
    UK
    +1,129
    I thought your panel was HD, if it is SD then it is the same as my PW7.... try 1024 x 576 (DVI) or 1280 x 720 (VGA). If you are playing back PAL material use 50hz refresh, for NTSC use 60hz refresh.
    Then in XP go into display properties - appearance and enable extra large font types, under effects use clear type fonts, and you can experiment with some other settings in there.
    It also worth getting the DVE disc, or another calibration tool and running that from your PC as settings on the panel can make a lot of difference to how clear the PC output looks.
  9. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,309
    63
    +127
    don't forget to change display in panny menu to WVGA would be VGA by default, this will improve picture when feeding a widscreen input into it from PC.
  10. Rambles
    Rambles
    Jul 14, 2004
    8,146
    UK
    +1,129
    Is this on viera's or PW7's too?
  11. Serpico
    Serpico
    Jun 22, 2002
    345
    Hull
    +7
    In Windows:
    Right click on a blank area of the Desktop and choose [Properties]
    Click on the Appearance Tab; Click Effects
    Check the box: Use the following method to smooth edges of screen fonts
    In the drop down box select: Clear Type
    That should improve things.
  12. Rambles
    Rambles
    Jul 14, 2004
    8,146
    UK
    +1,129
    I just said that!
  13. Serpico
    Serpico
    Jun 22, 2002
    345
    Hull
    +7
    Would a mod please move my post above Lisa's so I look less like an arse?
    Thanks in advance. :lease:
  14. Rambles
    Rambles
    Jul 14, 2004
    8,146
    UK
    +1,129
    :rotfl: no - leave it in!
