Fusion Website now up with products
Discussion in 'Digital TV & Video Players & Recorders' started by Dave Taylor, Jun 20, 2003.
Tags:
  1. Dave Taylor
    Dave Taylor
    Oct 7, 2001
    274
    High Wycombe, Bucks
    +15
    http://www.fusiondigitec.com
    Just noticed that the Fusion hold page has gone and now a real website is up and running with PVR product info.
  2. Patrick Navin
    Patrick Navin
    Am I the only one who's noticed the worrying "SoftMPEG" references all over the place on these devices? I'm not 100% sure these will be true bitstream recorders. Is it possible these are decoding to analogue and then recoding to mpeg? If so I see little point in bothering with them.
    anyone got any clarification?
    Patrick
  3. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    I recon it probably refers to software mpeg decoding with a standard CPU as opposed to dedicated hardware mpeg decoding.
  4. Patrick Navin
    Patrick Navin
    I can see why you'd say that CS, but if you notice on the literature they refer to different compression rates. This suggests some post-processing of the stream in order to fit programs to disk. I'm just wondering how much of an effect it will have on final picture quality. As it is we are stuck with the relatively low bandwidth of Freeview - meaning my Pace Twin's recordings are only ever as good as the transmission, any further reduction could render recordings unwatchable.
    P.
  5. avanzato
    avanzato
    Jan 21, 2003
    1,881
    Norfolk
    +61
    I've just had a look and there're four rates: Direct recording of the stream and then three variable bitrate options.
  6. pvr_uk
    pvr_uk
    At aleast this means you can back up to VCR / DVDR if you want. Unlike some others..
  7. as8602
    as8602
    Apr 15, 2003
    87
    +11
    *If* Fusion do release the products they're planning for and *if* they work as described (in contrast with the Pace Twin), then the Twin will be dead in the water in my mind.
    The Fusion PVR starts off with twice the Twin's HD size, plus has the ability to record at lower bit rates if you're desperate to squeeze more in. Plus you can archive off to DVD. About the only thing lacking is a USB/Ethernet output to read to/from a PC - though I can live without this given the built-in DVD burner.
    Hope they support a modicum of recording editing - I would just want to be able to trim the start/finish & remove sections (adverts) from the HD prior to archiving to DVD.
    And then there's the EPG. Am I alone in finding the Twin's EPG a bit useless - when it was briefly showing 24 hours it was agonising to navigate round - imaging having to go forwards through a 7-day EPG. The Fusion EPG *looks* infinitely easier to use.
    My current plan is to keep the Twin until an alternative arrives. Assuming that the Twin still isn't fully fit for purpose, it then goes back for a refund - the joys of consumer legislation - and Pace continue their decline.
  8. mortod
    mortod
    I do agree, but the Pace EPG did seem marginally quicker if you made effective use of Lists (eg a list with just BBC1/2, ITV/C5).
  9. pvr_uk
    pvr_uk
    I was just reading as well that Fusion now have several key ex-Pace engineers in their employ.
