Fusion VP4200S
Discussion in 'Plasma TVs Forum' started by richard.hewett, Feb 12, 2005.
  1. richard.hewett
    richard.hewett
    Jan 29, 2005
    53
    Reading
    Does anyone have any info on this panel ? Richer sounds have it @ £1800 and it's supposed to be HDTV ready.
    I've had a quick look around, but the only links I get are for the Richer Sounds site. I'd really like to get some tech info on this, so that I can compare it to a Pio 435XDE.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It's perfectly possible that it's a richer own brand, you only have to order 250 or so to do this. Ask specifically if it supports 720p at 50Hz over an HDCP digital connection, and ask the origin of the glass.
  3. richard.hewett
    richard.hewett
    Jan 29, 2005
    53
    Reading
  4. Plasmajoe
    Plasmajoe
    Fusion is an LG screen, or to be correct its manufactured by Philips.
    I am happy with mine, great picture, but its the first i have had so i don't know any different. (£1500.00 at Richer Sounds)
  5. billgreenwood
    billgreenwood
    it is an own-brand. I asked the guy in Richer Sounds :)
