Fuse question when changing Sagem lamp
Discussion in 'General TV Discussions Forum' started by nevtra, Sep 21, 2007.
  1. nevtra
    nevtra
    Hi, my lamp has popped and i've managed to find an authentic replacement on ebay for just 99 pounds. My question is this, the casing on the lamp has a fuse which i'm assuming has blown, does anyone know the type and rating of this fuse and where i can pick on up from.
    Any help much appreciated
  2. Ragnarok
    Ragnarok
    Jan 15, 2005
    1,281
    63
    +142
    I beleve they are ether 315mA or 0.5A/500mA quick blow fuses. they are marked F315, F500 or F0.5A
    Crazy thing for me the fuse last time i swiched it didn't blow but it still reset the lamp counter, so i removed it and all is as it should be apart from my new bulb hasn't turned up yet.
  3. nevtra
    nevtra
    Thanks for the info mate, have you any idea where to get one?
  4. stu232
    stu232
    Jul 8, 2006
    121
    +4
    I got mine on eBay mate.
