Fuse problem with SVS 16-46 PC-Plus
ces456
I have a 16-46 PC-Plus and as soon as I turn the power on, its fuse
blows (the 5 amp fuse below the power cord). This happens every time
I turn the subwoofer on and before it receives a signal from the
receiver. I've tried a different subwoofer with the same receiver and
using the same power outlet and do not have the same problem with the
other subwoofer - only with the SVS. Any ideas what might be wrong
and how I can fix it? Thanks.
stevefish69
I presume that this is an original import as the big tube was not available in the UK from from SubSonic sounds.
IMO sounds like a problem with the amp module, and i doubt if it could be fixed without swapping out the complete board.
Why not drop SVS Technical support an e.mail and see what they say. How old is the Sub (date should be on sticker at back) as it will be covered under warrenty if under 3 years old :smashin:
If not, i'm sure they will be able to sort you out with spares as required.
ces456
Yeah, I did drop a line to SVS tech support. I think I got it in August, 2005 - so it's just out of warranty - bummer.
stevefish69
Sods law - Post back how you get on when they reply, and i hope you get it sorted quickly
