Fuse on Paradigm Servo-15 started to blow
Discussion in 'Subwoofers' started by trevsorbie, Feb 23, 2005.
  1. trevsorbie
    trevsorbie
    Feb 23, 2005
    50
    I've had a servo-15 for several years now and until a couple of months ago, never had a problem with it.
    I use the sub in 'auto' power mode - switched on when it receives a signal.
    A while ago I noticed it wasn't working and removed the rear cover to find the fuse had blown. I took the fuse to get a replacement but lost it! I calculated the required rating would be 2A and got a couple of replacements.
    I thought the fuse blowing may have been caused by a loose power connector.
    Replacing the fuse resulted in the sub working for a whole film! The next morning I switched on my amp (TAG AV32R) and heard the fuse in the sub blow straight away.
    I thought this may then be caused by the 'auto' mode having a problem so replaced the fuse and switched to the 'always on' position. The fuse blew on power on.
    Is the 2A rating for the fuse correct?
    If so I'm a little stuck as to what to do. Reading some threads indicates the vdr may need uprating to 275v but I was wondering if there might be anything else I've missed before I go ahead and make the change?
    The vdr isn't close to the fuse and has no charing to indicate it is shorting with the fuse.
    Any help would be much appreciated.
    Trev
  2. sonic65
    sonic65
    Jan 22, 2005
    158
    Bourne
    Hi Trev
    Are you using the correct type of fuse.
    There are quick blow, slow blow etc. It is essential to use the right one.
    Haven't got a servo 15 (yet) so can't help much further.
    sonic65
  3. trevsorbie
    trevsorbie
    Feb 23, 2005
    50
    I'm not sure what type of fuse to replace it with as I lost the original. I've just been using some radio/tv fuses my father had spare!
    Anyone able to help with the correct type of fuse to be using as sonic65 suggests?
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    wrap a bit of tin foil round the fuse
    stick it back in, problem solved.
    PS
    if you kill yourself, I didn't tell you to do this.
  5. SamirP
    SamirP
    Apr 28, 2003
    1,317
    South Of The River
    +39
  6. trevsorbie
    trevsorbie
    Feb 23, 2005
    50
    Thanks - obviously missed that thread.
  7. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,411
    41
    Berkshire
    +17
    I am not giving approval of using a higher fuse rating, but i have used a slow blow 3.15a for over a year no probs.
