Funny noice coming from car amplifier
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by boryc1982, Apr 24, 2007.
  1. boryc1982
    boryc1982
    Ive got my amp wired up in my car with the subwoofers etc etc as per usual.
    The trouble is tht the amp is making a weird noise. Its hard to drscribe, ive heard like a buzzing noice, a whislte, or it sounds like my cars electric :) so its pretty hard to explain. The pitch changes when im driving.
    Its coming from the amplifier and if you mess with the switches on it bass boost etc the pitch of the noise changes but it doesnt go away.
    Ive done a number of things tht i thought or have been told may have affected it. I have changed the leads, i have made sure they are connected probably, no loose connections. I have the RCA running one side with the Power alternate side.
    Urm i think thats about it ,:lease: any ideas out their , anyone had this problem or could help i would be grateful , thanks
  2. Ayub
    Ayub
    Oct 15, 2003
    6,647
    Bradford
    +612
    3 reasons...
    1 poor ground on earth termninal
    2 poor connection rca' grounding
    3 ground track blown on amp
  3. Immy408
    Immy408
    Apr 29, 2007
    It's probably a poor ground, where you have grounded it, make sure you sand down the area so that it is a good and clean connection. It may also be a ground loop so make sure that none of your speakers are touching any metal such as supports etc in the door where you have mounted them, this includes the magnets touching any metal, ie any metal part of the speaker which could conduct. Hope this helps :)
  4. Kaos_vauxhall
    Kaos_vauxhall
    Apr 15, 2007
    94
    +16
    geeza its not any of those I think all you need is a noise filter the noise your talking about is a noise like a whistling rite it like when you accelerate it makes that noise or when you rev the engine yeah
    You need a filter
    Technically known as a LOOP ISOLATOR
    it will reduce that noise to nearly nothing and you wont hear it again :hiya: :D
