Fully Wired & RGB only Scarts
Discussion in 'Cables & Switches' started by cwoj, Nov 11, 2004.
  1. cwoj
    cwoj
    Why buy RGB only scarts when you can buy fully wired ones...that carry the rgb signal. I am assuming that by removing the other cores you get a better quality signal? is this correct or am i bonkers? :lesson:
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,424
    The Borders
    +3,231
    cwoj
    The RGB only SCART cables tend to use a 4 or 5 core only video Multicore - this allows you to have much thicker conductors per line plus heaver screening in the same diameter cabling as a fully wired cable; which has to fit many more cores into the same space.
    Best regards
    Joe
