Full Spectrum Warrior Demo - anyone else having probs?
Discussion in 'PC Gaming & Rigs' started by cerebros, Sep 19, 2004.
  1. cerebros
    cerebros
    Dec 27, 2002
    1,318
    48
    Leicester
    +30
    Downloaded the FSW demo yesterday but only got round to trying to play this afternoon...
    Only I can't because it says there's a file called FSW2.dll missing... Tried re-installing but didn't work. Anyone got any ideas of where to get this file from?
    Also the install was a bit of a PITA as even though I wanted to install to my D: partition (where all my applications are) it still wanted nearly 600MB of space on C: which meant having to clear a couple of hundred megs of stuff as it wouldn't allow you to substitute a drive in place of C:. Annoying....
  2. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    I instaled the demo with no problems. U should uninstall then install again. Also switch off any anitvirus software before you instal.
    Im not sure if FSW needs DX9C, but it might so install that too. Cant think of anything else. If its a file problem then it could be due to a file being blocked by something like anti virus software or a firewall? Did u install SP2?
    That could be the problem, but Im not sure!
  3. cerebros
    cerebros
    Dec 27, 2002
    1,318
    48
    Leicester
    +30
    I tried all that before posting... I'm on Win2k so the SP2 issues don't apply...
  4. cerebros
    cerebros
    Dec 27, 2002
    1,318
    48
    Leicester
    +30
