Full screen video display (usb input)
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by mordzy, Apr 22, 2005.
  1. mordzy
    mordzy
    Feb 7, 2005
    67
    Hiya, not sure if this is the right forum but here goes.
    I have a little USB2 video capture device. usually use windows movie maker to capture stuff.. but what i want to do is watch TV or play on the xbox through my laptop. i can do this already but its in a tiny window.
    Does anyone know of any software where i can full screen window. even if its some capture software when i can max the preview screen...
    thanks guys
  2. Brian110507
    Brian110507
    Windows MovieMaker will play full screen - under the preview window but above the 'play' button is a small icon showing a box with an arrow in it - click on it to get full screen playback, press ESC to reset.
  3. mordzy
    mordzy
    Feb 7, 2005
    67
    any apps dedicated for this?
  4. mordzy
    mordzy
    Feb 7, 2005
    67
    dont have a play button on the preview screen.. only the start and stop capture buttons
  5. mordzy
    mordzy
    Feb 7, 2005
    67
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    I would say the chances are that the poor quality at full screen is far more likely caused by the graphics card in your laptop. Full screen, full motion graphics requires a lot of memory and processing power to do well, and the chances are that a laptop will not have a top specs graphics card. I would therefore think you are likely to be stuck with a poor quality image or a small window.
    Mark.
