Full res video capture
Discussion in 'Desktop & Laptop Computers Forum' started by Peter Parker, Nov 3, 2003.
  1. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,180
    UK.
    +2,721
    What's a good but relatively inexpensive capture card for capturing a composite video signal (and stereo audio) so that it can be recorded at 720 x 576?
    I'd like to be able to then convert it to mpg2 for recording to DVD.
    I've an old Pinnacle PCTV Rave card, but that doesn't seem up to the job.
    TIA
    Gary.
  2. Loafer316
    Loafer316
    Apr 8, 2003
    330
    The Packard Bell card mentioned on these forums and available at pcworld is pretty good. Combine that with something like iuVCR and you can capture in full screen with a lossless codec like Huffyuv and convert it to DVD standard using Tmpgenc or CCE. worked for me.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    There are several new capture devices that connect to a PC via USB2.0 from the likes of Belkin, Pinnacle, Ulead etc. If you don't have USB2.0 then a PCI card can be added to the PC for around £20 and then the analogue capture device for around £50. These should include software for capture & encoding.
    Mark.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    www.ebuyer.co.uk
    Belkin Hi-speed USB2 DVD Creator £47.75 inc VAT
    QuickFind code: 46431
    Mark.
  5. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    Their web is 404'ing atm but www.vidac.de and look for the "Movie Magic Plus" hardware MPEG encoder capture card for around 200 Euro.
    Full size capture direct to MPEG1, MPEG2 at a bitrate of your choice, complete with event timer and PVR capability.
    Recent example: Capture prog from Sky via s-video, open Ulead DVD workshop, cut out menu stage, burn direct to DVD+RW in approx 25 mins. Watch disc in another room.
    The plus version can also re-encode ripped VOBs and acts as a plugin for Adobe Premiere. Also managed to correct a d/loaded SVCD movie which would not open in TMPGenc, Premiere, or any other s/ware.
    The card completely ignores Macrovision,CGMS etc, so have also copied kids entire Disney/Barney etc VHS onto DVD or VCD
  6. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,180
    UK.
    +2,721
    Cheers Mark, the Belkin device looks just the job, and inexpensive too. :)
    Thanks to all who replied.
    Gary.
