sub3marathonman
I thought I had things completed, I put the cables behind the wall, attached the full-motion wall mount, and got all the cables connected to the TV. And then I found a problem I'd never thought of.
I found out it is not possible to push the tv (LG OLED77CXPUA) back to the wall, as the Zeskit 4K HDMI cables are thick and not flexible. I've tried to maximize the length of the cables to allow for a nice curve, but they are still pushing outward. There is also the HDMI #4 port which requires a straight connection to the TV, which doesn't seem possible to connect without extreme outward pressure on the TV by the inflexible cable. It is bad enough with the other three, as the tv has a little ridge there which puts pressure on the cables and thus the HDMI port, rather than allowing them to extend further outward.
I'm wondering if people have put a little bracket to hold the cables tight against the wall? But with a bracket, it then becomes a procedure to extend the tv outward, as the cables then need further slack, but that would be OK as it isn't moved on a regular basis. I'm also worried about putting pressure on the HDMI connector on the tv itself.
Any help or advice is greatly appreciated.
