Full Monitor Audio Silver for 7.1
Discussion in 'Home Cinema Speakers' started by DexS, May 27, 2003.
  1. DexS
    DexS
    I am kind of in a dilemma now. I have a 7.1 setup consisting for 9i and 12i for the fronts, 4i for the rear and Jamo Dipoles for the sides. Recently I have the chance to acquire a pair of 7i and was considering whether I should get them for the rears and moved my 4i to the sides. Will this be a overkill for using 7i as rear ? The 7i can be for mine at 250 quids. Or should I save the 250 and use them instead for DVDs. My room is 8m by 5m.
    Thanks for your comments.
    CHeers
