Fujitsu Plasma problem - please help
Discussion in 'General TV Discussions Forum' started by farnell, May 12, 2001.
  1. farnell
    farnell
    I have recently bought a second hand Fujitsu plasma tv. As it had no tv tuner I thought I'd be able to use the tv tuner on my nicam vcr. I tried scart to s-video, although as I presumed this gave me a black&white grainy picture. I then tried scart to composite video (although I had to use a bnc connector on the end of the video cable to match with the fujitsu) and this gave no picture at all. I can get sound through the audio leads. The other tv connects are 3 bnc component connects and a computer connect.
    How can I get terrestiasl tv ? Help I've got the plasma but no tv to watch. (However it's great for dvd's).
    Steve
  2. encaser
    encaser
    Mar 15, 2001
    3,375
    Suffolk/Essex
    +1,041
    have you checked no s-vid switching nec on set or in menu, or tried a straight connect from vid as composite only - i.e. whip off the composite lead you'd use vcr to tv and switch vcr to composite, not scart control, out as a test if not solution in mean time?
    I had a vid which needed both comp and scart to get a pic on tv - not on scart control before anyone sais was! - which may be case with you, worth a go.
    Encaser
  3. Guest
    Steve, if all else fails - Keene Electronics-01332 830550 or Lektropacks www.lektropacks.co.uk - 08700 711911 should have a solution.
    Regards
    Barrie
  4. Guest
    ...hope you had luck with that fix, how much did the Plasma set you back anyways?
  5. ISCM
    ISCM
    You could always get an S-VHS video and then there would be no problem. This would give you a much better picture anyway. :D ;) :D ;)
  6. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
