Fujitsu plasma horror
Discussion in 'Plasma TVs' started by Mr.D, Sep 18, 2003.
  1. Mr.D
    Mr.D
    Jul 14, 2000
    11,051
    +1,130
    I've just seen a fujitsu 42" plasma at work : being fed RGB from a wharfedale player by the looks of things. Don't know the model number.
    Are they always this bad?
    Terrible deinterlacing, terrible scaling artifacts , terrible banding . Very very clipped looking picture and the unit has supposedly been calibrated.
    Huge lipsync errors also sound way ahead of video.
  2. nathan_silly
    nathan_silly
    You're trolling surely? Don't you know Plasma's have awesome picture quality? ;)
    Oh yeah my local dealer has a Fujitsu HD panel. What you said. :)
  3. Timmy B
    Timmy B
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,051
    +1,130
    Thanks for the post Timmy but it didn't really help.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    What model was it?????
    VHA or HHA or VCA?
    we have one at work and the new panny PA20 is far superior than the Fujitsu!!!!
  6. Timmy B
    Timmy B
    The answer then, is no, they are not all that bad. I recently replaced my 56 inch 100hz toshiba rptv with a panny 6 and apart from the fact that my tosh 510 dvd player wont work with it, it is alot better.
  7. Dax
    Dax
    I've got a Fujitsu VHA20 and am very happy with it. AFAIK it's Panny 5 glass with better electronics (AVM chip).
  8. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    If it's connected with scart, several points. It doesn't auto sense the input, and unless you go into the menu and tell it to look for RGB it's running on composite. Also, the scart board is a founder member of the 'not terribly good club'. The plasma is fine, as such, sounds like lousy setup.
  9. Dax
    Dax
    My panel doesn't have SCART inputs at all, but that's fine since here in Australia SCART is very rarely used by anything. It does have two sets of component inputs, which is very welcome.
  10. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    I'd rather have more component inputs rather than scart sockets these days...
