fujitsu plasma and digibox
Discussion in 'Plasma TVs Forum' started by ajmalsheikh, Apr 22, 2002.
  1. ajmalsheikh
    ajmalsheikh
    Hi, I`d like to pick your expert brains for a moment.
    On wednesday I`m due to take delivery of my first home cinema system
    It comprises of:
    Fujitsu 4242 plasma
    Sony STR 1070 amp/receiver
    Toshiba SD510e dvd player
    Bose acoustimass 10 series II speakers/sub
    the plasma will have the following inputs:
    1 x S-video
    1 x Composite
    1 x Component (3 x BNC)
    1 x RGB (15 pin 3 row VGA)
    1 x RGB (5 x BNC)
    the dvd will connect via component input (3x BNC) as the toshiba has the same. Now my question is regarding how to best hook the plasma up to my first generation sky digibox.
    I have seen the following solutions from:
    A) Scart rgb > 5 x BNC or 15 pin VGA from www.keene.co.uk/pages/cat/11lea/111-2.html#SGB
    or
    B) Scart > S-Video or RGB convertor boxes from http://www.rgbtosvideo.com/
    thanks!
  2. encaser
    encaser
    Mar 15, 2001
    3,584
    Suffolk/Essex
    +1,198
    Option B. scart rgb to rgb box ->vga -> vga cable ->vga plasma
    Been informed that the Keene 'solution' is not so trustworthy, stay clear.;)
  3. ajmalsheikh
    ajmalsheikh
    thanks! I`ll give this method a go as soon as I get the rest of it hooked up. will have to run it on composite for the moment
  4. Skillz
    Skillz
    Have you considered conecting up your DVD player using an RGB cable to the BNC terminals on the back?
    What I have figured, and any one correct me if I am wrong, is that SCART RGB consist of RGBS, where the H and V sync signals are carried along the cable. Now, the Fujitsu will accept this, (if you look at the back of the screen on of the inputs is nmarked H/CS (for composite sync).
    This should work for the DVD player(put it into RGB mode), and if you connect the Sky box to the DVD player, using an RGB SCART, the DVD will carry the RGB signal through from the Sky box,
    Hence you then should only need to connect up to the screen using the RGB BNC terminals.
    (but you will need to connect a video player to the composite BNC seperatly, as they only seen to offer composite outputs)
    This is all in theory, as I am still awaiting my Sony DVD player.
    Hope this helps, and is clear
    Shilen
