Fujitsu PDS4212E-H plasma display fault
Discussion in 'Plasma TVs Forum' started by squareeyed1, Aug 17, 2005.
  1. squareeyed1
    squareeyed1
    Aug 15, 2005
    Does anyone know of a repairer for these in or near Hampshire. Had a quote
    from a company up country but it was in excess of £500, the screen is 4 or 5 years old so no warranty.
    The problem is that when turned on for a few minutes the screen goes blank, no on screen graphics, power indicator stays green, two little fans above power supply are working, two big ones at top corners are not running.
    Thanks for any help.
  2. Maniac0Maniac
    Maniac0Maniac
    Apr 25, 2011
    Ever found a sollution to this? I have the same problem on mine. Would like to know if you solved it.
