Fujitsu P42HHS10 for £1999?
Discussion in 'Plasma TVs Forum' started by JohnP, Mar 9, 2005.
  1. JohnP
    JohnP
    I'm a plasma virgin, but is this a good deal at:
    www.electricshop.com/invt/4066fuj111267a&bklist=icat,3,,plasmatvs
    The panel looked good when I saw it working elsewhere recently. Claims to be HD-ready - but should I go for the cheaper standard Panny?
    I just use SCART between my current TV and Video/DVD/Freeview boxes.
    Any thoughts? :lease:
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It's certainly not HD ready, they are just about to release the HHS40, so it's a bit old. I think if you like this panel you'd get a more up to date almost identical panel from Hitachi.
  3. JohnP
    JohnP
    Thanks, I realise the model 40 is about to hit the streets, but the 10 and 30 seemed to have been appreciated by most reviewers in the past - though the ALIS is not to everyone's (or your) taste!
    Just seemed that the pixel resolution on the Fuji was rather better than the Panny PWB6 or 7. Is it really not HD ready? - salesman kept saying it was. Might it have PC inputs to drive at PC resolutions?
    John
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Never mind my personal tastes, it needs to have a digital video input that can run 720p and 1080i both at 50Hz and with HDCP compliance to be hdtv ready. It does not have this feature. I don't think it's a particular bargain, as I say you can buy an up to date Hitachi for less than that. Same glass, only the warranty will be different.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    fujitsu processing is better than the Hitachis.......... but it is NOT HD ready!!! 50Hz HDCP is the killer.Also the 10 series do/did suffer horizontal banding....£2k almost buys you a Panny SD panel and scaler!!!!! i would atke the panny and scaler......
  6. JohnP
    JohnP
    Thanks guys, your comments much appreciated. I'll look into Hitachi's and think more about Pannys.
