fujitsu P42HHA30ES+PTE1300
Discussion in 'Plasma TVs Forum' started by mods, Oct 28, 2004.
  1. mods
    mods
    Oct 25, 2004
    44
    11
    Is this model any good? £2526@3dsolutions bargain? cheers :)
  2. icehockeyboy
    icehockeyboy
    Sep 27, 2004
    29
    Nottingham
    well....ive got the hha30..and its a brilliant mochine!.......erm scuse my ignorance, but what is the pte 1300?
  3. moku
    moku
    Sep 19, 2004
    88
    Manchester
    PTE 1300 is the Video Connector Board which allows you to connection of TV Tuner?Digibox (Sky or Freeview), DVD Player, VHS etc. This board has the Component input, Scart input, Audio 1 & 2 inputs and Left & Right Speaker connecyions. Without the PTE 1300 the only connector on the display panel is just the VGA input.
    MODS,
    Re your question, its a an exceptionally good unit, excellent picture quality and IMHO one of the best display panels around if not the best. Its a high end unit and therefore expect to pay top money for it but I think the price you've been quoted is a bargain and worth giving it a serious thought.
  4. moku
    moku
    Sep 19, 2004
    88
    Manchester
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    HHA30ES is a very nice panel but go and see it in action very cinematoc but not very high contrast and not HiDef but ALIS (£2.5K gets you a Panny PHD7 which is a difficult call..........)
  6. The Nightfly
    The Nightfly
    Aug 31, 2002
    821
    The New Frontier
    +24
    I saw this screen recently and thought it was very good. A bit beyond my budget but it was good enough to make me research further. A few searches on the American AVS forum would indicate that the latest Fujitsu screens are rated very highly over there.
    Hornydragon, I'm not sure what criteria must be passed before a screen is considered Hidef but the smaller pixels seemed to make an improvement in fine detail and screen-door compared to the standard definition plasmas I've seen so far.
    Allan
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    768+ vertical res (alis doesnt match this despite the quoted 1024 res) they Fujitsus are very good used to sell loads with BOSE lifestyle systems........ look great ithe S-video and componet......very cinematic IMO and for a TV replacement excellent (have some draw backs...but so do all)
  8. The Nightfly
    The Nightfly
    Aug 31, 2002
    821
    The New Frontier
    +24
    Horny,
    Do you know if the interlaced fields on an ALIS panel are displaying identical information ? I suppose worst case is that they are and therefore the 'effective' resolution on these panels is 1024x512 which puts them somewhere in between the SD and HD Pannys.
    What is the chance that the onboard video processing on something like the Fujitsu is actually attempting to interpolate the frames to try and smooth the image somewhat ? If that was the case then theoretically these screens may actually look a bit smoother than something like the HD Panny.
    Allan
  9. moku
    moku
    Sep 19, 2004
    88
    Manchester
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    allan you are correct fujitsu site has a good animated explination and the AVM processor does exactly that smooth it all out........
