Fujitsu HHA 30
Discussion in 'Plasma TVs Forum' started by hutchys, Oct 12, 2004.
  1. hutchys
    hutchys
    Feb 4, 2002
    135
    16
    hello,
    I am thinking of getting a Fujitsu hha 30 (for £2499 inc stand) I know this is a ALIS screen but what does this mean regarding HD signals can you not use HD on an ALIS because the screen does it's own stuff? thus not showing the HD material in it's true colours so to speak,or would the VHA be a better bet for HD material.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50
    OK HHA is incredible with SD interlaced video as its internal electronics are superb........... VHA is very very very very very good and my top pick for a SD plasma but if you want HD go for an HD screen and 50XHA is lovely....................
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    did you get the hint?
  4. hutchys
    hutchys
    Feb 4, 2002
    135
    16
    Yes I got the hint HD but 50" is really to big for my room. What I was asking about HD was will the HHA look Ok when/if hd finally arrives either via dvd or sky? due to ALIS or would an SD panel look better for this either a VHA or PW6. i have seen sky on the HHA and it looked good even the football looked fine. Also HD do you know if the HHA has the same electronics as the HHS?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    HHS is a HHA with tuner type box that gives more connectivity (basiclly a bespoke scaler type switch box) I have not run HD on an HHA so cant say but liam may have seen it..... and that 50 XHA is sooooooooooooooo good for the money....... how big is your room?
  6. hutchys
    hutchys
    Feb 4, 2002
    135
    16
    I am sat roughly 10 foot away from the screen HD do you know the prices of 50" screens HD?
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    £3.5k for a 50 XHA from liam at progressive bargain.....
