Fujitsu 42VHA30 and 42VHA31 ?
Discussion in 'Plasma TVs Forum' started by Fishbones, Jun 25, 2004.
  1. Fishbones
    Fishbones
    Jan 26, 2004
    127
    Madeira
    Has anyone seen the VHA31 yet? How does it compare to the VHA30? (Having a samsung glass :eek: )
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I've seen them side by side. The 31 is not bad, but I think it is a retrograde step. I think they did it to cut costs. As the saying goes, there's not much in the world you can't make cheaper by making it worse.
  3. Rui Barata
    Rui Barata
    May 27, 2004
    Hihi Maw,
    Did you seen any particular difference between VHA30 and 31, or the major difference are the manufacturer of the glass.
    Tks in advance for your help.
  4. Fishbones
    Fishbones
    Jan 26, 2004
    127
    Madeira
    Does the VHA31 have DVI?
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Little visible difference, no DVI
