Fujitsu 42" Plasmavision Display problem
Discussion in 'Plasma TVs Forum' started by nid2know, Aug 4, 2004.
  1. nid2know
    nid2know
    Hello guys,
    I have Fujitsu Plasmavision 42 inch, which I bought from a guy who was relocating abroad. It worked fine when I picked it up, but I didn’t pay attention to how it was connected. It came with a cable which was connected to its R G B inputs and the V terminal and Scart on the other end.
    It wasn’t displaying when I connected it directly to my Sky Set Top Box or any of my DVDs.
    I rectified the problem by buying a CYP Scart to YUV (RGB) converter. I now have a greenish display even though everything seems normal underneath. Someone suggested I bought a Q Sync, but it was working fine without this being used. Does anyone have any suggestion please? I am approaching the point of desperation. Thanks.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I'd need to know the model number. It sounds like you are displaying YUV on a RGB input, you might find you can change this in the screen setup menu, but some Fujitsus are RGB only. If so, you have bought the wrong converter, and you need the RGBHV version, which is easiest to connect to the VGA 15 pin sub d socket on the screen with a good quality computer monitor (VGA) lead. Try the menu, and the model number and post again.
