Fuji VHA30 - Should fans be working ?
jspr
Only on my third day with my new Fuji VHA30 and have found the service menu which shows the number of hours but also noticed there were options for turning on fans (currently turned off) - I also noticed the temperature was showing 42C ! Should I be worried ? There is nothing in the manual about fans (or even about the service menu).
jspr
Urotsukidoji
Thanks for that - by the way I tried sending you a PM in reply to your previous question but your mailbox was full !
jspr
To get into service menu on Fuji VHA30, press and hold the enter key for about 5 secs.
Similar threads
