Fuji S304
Discussion in 'Photography Forums' started by klondike, Apr 27, 2005.
  1. klondike
    klondike
    Can anyone help. When I try and load my picture/movies onto my PC through my USB connection, the screen shows:
    USB
    DSC
    and nothing happens? Is this an error?
    PLEASE HELP !!!
    Peter
  2. geofftelforduk
    geofftelforduk
    May 21, 2004
    1,252
    Northern Ireland
    +138
    Depends on what operating system your computer is running! IF you are running windows 2000 or windows XP it is more than likely that your computer will automatically pick the camera up as a removable disk!
    Try this:
    1. Open Windows Explorer or My Computer
    2. Check to see if there is a Removable Disk drive there in the list of drives
    3. If there is, then explore the removable disk
    4. There will be a folder called DCIM (I think), open it and then there will be another folder inside the DCIM folder. OPen it aswell and you photos should be in there!!
    Hope this helps!
  3. klondike
    klondike
    Thanks Geoff. I have never had any problem before and have always been able to pick up my pictures from Widows Explorer - no problem. The pictures don't seem to be transferring onto my PC. Usually the green light on the camera will fash to indicate the transfer is going ahead ok - but now it is not I use XP
    klondike
  4. geofftelforduk
    geofftelforduk
    May 21, 2004
    1,252
    Northern Ireland
    +138
    :eek: :eek: :eek: I know you meant "Windows Explorer"!!!
