Fuji finepix S304 too slow
Discussion in 'Photography Forums' started by freddyuk, Jun 17, 2005.
  1. freddyuk
    freddyuk
    Sep 27, 2004
    210
    I have just been on a trip using my Fuji for outdoor shots.
    Whilst this has been a good camera its limitations were obvious when i tried to catch action shots of Eagles and Killer Whales. Lots of empty sky and water!
    Having checked the forums i see shutter lag is an issue with this camera so should i revert to my old 35mm SLR for these type of shots or is there a digital camera that will come close to the SLR.
    I also have the 1.5x zoom lens which does not really "get there" in my view.
    I am not an expert so would appreciate some advice.
    I did use the video option but this uses up memory.
    Many thanks
    Freddy
  2. wildone
    wildone
    Mar 30, 2004
    59
    Cambridgeshire
    I totally sympathise - my S304 (out on loan at he mo - bought a Nikon D70 kit about five weeks ago) was hopeless. Took it to a cricket match a couple of years ago with the intention of shooting closeups from the boundary. The 6x zoom took me in far enough but most of the time, all I got was "after" shots (ie. after the shot). Eventually I had to try and anticipate, and press the shutter button before a shot was played - most annoying.
    If you're after a decent budget DSLR, look at the D70 and Canon EOS350D for starters. Nikon have recently announced the D50 and D70s - others more experienced in these matters will offer more detailed advice.
  3. martynk
    martynk
    I agree. DSLRs pretty much eliminate the problem - at a price - but I believe some of the newer P & S models are a lot better than the older ones, and less expensive. Sorry I can't suggest any particular cameras, because I've decided to buy a DSLR when I can afford it, and I'm not really current with P & S development, but I'm sure someone will give you a recommendation. The DSLR is the only realistic option if you're serious about wildlife though, and prices are coming down.
