fuji digi printer nx70 help
Discussion in 'Photography Forums' started by yorky22, Apr 27, 2003.
  1. yorky22
    yorky22
    hi all
    hope someone can help bought above printer second hand,no instructions when i put smart card in only shows pics that i have allterd after taking them others just a ? against them,it is a 128 mb card
    regards
  2. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    Is this something to do with the embedded dpof info. Maybe when you edit it it doesnt keep the data used for direct printing.
    This is a 100% guess !
