Fugipix M603 Help Wanted
Discussion in 'Photography Forums' started by sofaboy, Feb 15, 2003.
  1. sofaboy
    sofaboy
    Hello all,
    I wanna buy a Fugipix M603 with a 1GH Card.
    Can anyone tell me of any web sites which sell this cam cheap (or at least a competative deal) or give me any information good or bad about this cam.
    Are there any digital cameras which are as good but cheaper or can I spend a bit more and get a better deal??
    I really dont know alot about Digital cams so any information will be a help...
    Thanks Fellas.:smashin:
  2. Just_Dabbling
    Just_Dabbling
    What might be a good idea is to run it through pricerunner.co.uk, at least then you would get an idea on the prices being offered accross the web.
    I'm pretty sure when I looked a couple of weeks ago, it was being offered with different memory "packages" and but I think they only went up to 512Mb.
  3. sofaboy
    sofaboy
    Cheers mate i'll give thata look
