FTV card
Discussion in 'Satellite TV, Sky TV & FreeSat' started by rutters, May 29, 2002.
  1. rutters
    rutters
    May 19, 2002
    210
    16
    Ok, so I've got the signal locked and put in a FTV card. It's been in for 24 hours but when I try to select a channel it says 'searching for listings' then it switches itself off..
    any ideas ?
    cheers
  2. swarrans
    swarrans
    Dec 21, 2001
    409
    16
    Kent, UK
    I don't want to suggest stupid things, but did the digibox work before with a subscription card? I only ask because the symptoms you've described sound like a broken digibox (a lot of the old Grundig boxes do stuff like that when they're getting on a bit).
