FTP into Xbox
Discussion in 'Xbox Forums' started by chrislad, Jul 27, 2005.
  1. chrislad
    chrislad
    May 6, 2005
    5,816
    83
    Rep. of Ireland
    +145
    Trying to ftp into my Xbox (modded), with no luck
    Using WinSCP. Using EvoX.
    A quick simple guide would be appreciated.
  2. chrislad
    chrislad
    May 6, 2005
    5,816
    83
    Rep. of Ireland
    +145
    Never mind. Got it sorted.
  3. nigelbb
    nigelbb
    Apr 4, 2005
    5,307
    103
    +491
    You are being too clever by half:) WinSCP does Secure FTP which EvoX doesn't. You need a standard FTP client like FlashFXP or even just fire up a DOS box &
    ftp ip.addressof.my.xbox
    then enter username & password as xbox (case-sensitive).
  4. chrislad
    chrislad
    May 6, 2005
    5,816
    83
    Rep. of Ireland
    +145
    Thanks. I found that software soon after I posted the thread.
    Main problem was that my wireless connection was conflicting with the Crossover LAN connection. Have to disable one before the other will work properly at the moment, but that's cool.
    Thanks regardless.
  5. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    yeah i think you have too or it get confused - that what i have to do too. but i dont ftp very often only a couple of times a week. but i've got two xbox's one for Live and one for XBMC :D
    Gary
