FTA lost QVC any advice please?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by CC1977, Jun 25, 2015.
  1. CC1977
    CC1977
    Dec 27, 2007
    172
    +10
    Hi. I have a FTA system with an Openbox running from the lnb on a sky dish. All works fine. A couple of months ago we lost all the QVC channels. The sky dish supports a sky install elsewhere in the house. QVC is fine via the main sky set up. I have tried a scan through the FTA Openbox but this doesn't fix the issue. Has anyone else had this problem and fixed it? or could help? thanks
  2. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,992
    +1,176
    Ensure you are using the correct TP details, 11954 H 27500 2/3.
    If that doesn't help replace the Sky box with the Openbox to test for cabling/lnb issues.
  3. pedro2000uk
    pedro2000uk
    Feb 20, 2009
    5,672
    Cheshire
    +1,085
    There's a lot of changes taking place this month at 28e btw as Eutelsat 28A leaves service & it's TP's payload are transferred over to various ASTRA 2 satellites & the new Astra 2G is also being brought into use at the same time- some channels & tps are being kept the same & some are changing frequencies / symbol rates etc..
    probably take several rescans this month until it's settled down
  4. CC1977
    CC1977
    Dec 27, 2007
    172
    +10
    thanks - I'll rescan from time to time
