FS2 speaker cable question
Joe Pineapples
1. Can anyone tell me the lengths of cable that come with the FS2's as standard?.
2. I will be opting for stands for both fronts and rears - probably something like the B-Tech 11's (stealth). Bearing this in mind, how thick/bulky is the cable? (i want to pass it up through the stands).
3. Can anyone suggest alternatives to the above stands,. at a similar price?.
cheers
Dean
cdm22
1) 1 x 15m length and 1 x 30m length IIRC so can then cut to length you need.
2) Cable is about one and a half cm wide, and about 2mm thick!
