FS:- 22MBPS Wireless Broadband Router (802.11b+ 22mbps)-Blueyonder/ntl
Discussion in 'Cable TV & Virgin Media TV' started by ferris57, Mar 19, 2005.
  1. ferris57
    ferris57
    Jan 18, 2003
    869
    802.11b+ Origo wireless cable router (22Mbps- twice the speed of bog standard 802.11b and 20% more range but still fully compatible with 802.11b and G). Ideal for sharing internet and streaming media.
    Here's a link:
    http://www.kanection.co.uk/product.php/177/58/
    Cracking router, loads of features and very easy to use. 100% reliable. Moving to dial up country in a few weeks- - so no need for it anymore.
    £30 inc insured delivery. Can take cheque or bank transfer. Advertised elsewhere.
    I have read and agreed to abide by the AV Forums trading rules : Confirmed.
  2. ferris57
    ferris57
    Jan 18, 2003
    869
  3. jmbrailsford
    jmbrailsford
    May 21, 2004
    3,814
    2
    83
    Fife, Scotland
    +231
    if I wanted to stream Internet and Audio throughout the house what else would I need?
    I assume a modem with ethernet connection and a media connection at hi-fi?
    Any info would help decide if this item is right for me.
    :smashin:
  4. ferris57
    ferris57
    Jan 18, 2003
    869
    hi there. yes you would need a cable modem (i.e ntl/telewest) and an ethernet cable which you would connect to the router. You then effectively have a wireless network set up which you can connect as many pc/laptops or wi-fi media streamers as you like.
    Any pc/laptop that you wish to connect wirelessly also needs some sort of wireless access point (usually usb or pci).
    This allows sharing of media, files, internet and printer. To stream media to your hi-fi you need to either connect one of your pc/laptop's directly to your hi-fi or use a wi-fi media streamer such as this:
    http://www.currys.co.uk/martprd/sto...1&category_oid=-21422&fm=null&sm=null&tm=null
    Hope this helps :)
  5. ferris57
    ferris57
    Jan 18, 2003
    869
    now pending on another forum.
