Frustrated Plasma Owner
Discussion in 'Projectors, Screens & Video Processors' started by forrestgump, Jun 11, 2005.
  1. forrestgump
    forrestgump
    Oct 31, 2000
    1,424
    huddersfield
    +49
    Had my Hitachi PM400E over a year now, nothing wrong with it apart from the obvious, no HDMi or DVi input. Question is, will a scaler for about a grand improve the picture remarkably? Or would I be better selling it and buying the new Hitachi model which can be bought for less than I paid for mine?
    Will a scaler allow HD material to be shown via the component input on my plasma?
    Is DVI or HDMI that much better than component? WILL not be using SKY even when they go hi=def, think they are a load of to...ers, would be using the screen for Hi Def DVD and HDV DVD
  2. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    I think you will find "HD" dvd will require DVI/HDMI with HDCP
    Skys service has been said will also require a HDCP display,
    so the best bet would be to stick your money towards getting an up to date display that has HDMI HDCP.
  3. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    But since you've got a plasma you're happy with already I would wait to see what offerings pan out from the various manufacturers as they come out with more HD Ready screens. Panny 8 series, new Pioneers etc. Never know, the price may fall too!!!
  4. 2towers
    2towers
    There may be limitation of a scaler on the component. My DVD player which has a scaler inside says that it can only support up to 576p on component as compared to 720p & 1080i on HDMI. Other more expensive analogue scaler may be better on component but to dump money in a dying analogue scaler is not worth. My mid-priced DVD palyer gives crisp & sharp pictures at 720p via a HDMI which I 've never got such from component.
    If I were you I'll definitely sell the old & buy a new HDMI stuff with a scaler DVD or standalone scaler.
  5. HeweyBoy101
    HeweyBoy101
    Jul 9, 2004
    856
    Lancing, West Sussex
    +60
    Or ...... buy a "box" for a couple of hundred quid to effectively remove HDCP from a DVI-D source and output via VGA (RGBHV) or component. I am trying this route currently with my Denon 3910, so that I can access the upscaled 1080i output on my (non HD) Philips Plasma. Worth a try I think. If it doesn't work I have 7 days to return it (www.lektropacks.co.uk)
    I'm hoping the results will be good enough to keep me happy for a couple of years (still seething that I spent £2k on a Plasma just 6 months before they reinvented the wheel and decided everything had to be digital and copy protected !).
  6. mouseboy
    mouseboy
    Hey HeweyBoy101,
    How did you get on with your HDCP removal unit?
    I'm wondering if that's the sort of thing i'm going to need. I have a Panny PW7, and i'm trying to get my head around what i'll nead to view HD content. Does the box you got act as a scalar too, and is that even a requirement?!
    I'm trying to plan for an XBOX2 SKY+HD and a HD DVD player. Obviously I could get a new Plasma, but i'd like to know the options for watching HD content using my existing setup - especially HDCP encrypted content!
    Thanks!
    Andy
  7. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +626
    Is this the device you are getting?
    http://www.lektropacks.com/view_item.php?product=37&&category=12
    It doesn't just transcode the dvi to rgbhv, it seems to output whatever resolution you set, not good for a device costing £230!
    Input Resolutions:
    PC (RGBHV) HDTV (YCbCr, YPbPr, RGBHV)
    VGA
    640x480
    60/72/75/85 Hz
    1080i
    1920x1080
    60 Hz
    VESA85
    640x400
    85 Hz
    720p
    1280x720
    60Hz
    VGA70
    720x400
    70 Hz
    576p
    720x576
    50Hz
    SVGA
    800x600
    60/72/75/85 Hz
    480p
    720x480
    60 Hz
    XGA
    1024x768
    60/70/75/85 Hz
    576i
    720x576
    50 Hz
    Mac
    1152x864
    70/75 Hz
    480i
    720x480
    60 Hz
    WXGA
    1280x768
    60 Hz
    1280A
    1280x960
    60 Hz
    SXGA
    1280x1024
    60Hz
    Output Resolutions:
    VGA
    640x480
    60/72/75/85 Hz
    1080i
    1920x1080
    60 Hz
    VESA85
    640x400
    85 Hz
    720p
    1280x720
    60Hz
    VGA70
    720x400
    70 Hz
    576p
    720x576
    50Hz
    SVGA
    800x600
    60/72/75/85 Hz
    480p
    720x480
    60 Hz
    XGA
    1024x768
    60/70/75/85 Hz
    Mac
    1152x864
    70/75 Hz
    WXGA
    1280x768
    60 Hz
    1280A
    1280x960
    60 Hz
    SXGA
    1280x1024
    60 Hz
    Distinct lack of 50Hz on needed reolutions too!
    the digital connections device is far better.
  8. Liam @ Prog AV
    Liam @ Prog AV
    Oct 18, 2002
    8,498
    Kent
    +827
    You're going to need something that converts HDCP DVI/HDMI into analogue component video. Although initially Sky HD will use component connections anyway so you're not too badly done. Nothing to worry about for the next couple years or so anyway
