Frozen picture on Sagem HD-D45
Discussion in 'General TV Discussions Forum' started by LoogieXX, May 5, 2005.
  1. LoogieXX
    LoogieXX
    Apr 20, 2005
    28
    Hello there
    My Sagem worked fine for about 2 months. Now10 minutes after switching it on the picture freeze. Sometimes it comes back after a few minutes. Other times when I power the unit off, on again all I get is a white screen with static on it. All the menu options are frozen at this point. The same happens even if the telly isn't plugged into any devices.
    Anybody else has seen this ?.. The picture started freezing a few weeks ago but it was only short and infrequent.. now I can't watch more than about 10 minutes a day before it stops working.. The temperature lamp is not showing and the unit is running off a APC UPS. So don't blame the power..
    Ps I have the green tint issue on the component input as well.
    I reported this to Sagem last friday and I'm waiting in huge anticipation, since they said they will call me back.
  2. Riva
    Riva
    Mar 8, 2005
    19
    LoogieXX
    Sorry your having problems with your HD-D45- I must say I have not heard of anyone else experiencing this fault but in my experience SAGEM`s customer support is very good and they will get you sorted out!
  3. jonathan
    jonathan
    Feb 8, 2002
    160
    19
    Kent
    I have found with mine that the picture kind of breaks up & then freezes for a few seconds, then corrects itself. During "the freeze" the sound carries on as normal. I put this down to the $ky feed, but maybe I am wrong. Is this how your problem first manifested itself?
  4. LoogieXX
    LoogieXX
    Apr 20, 2005
    28
    No it is not the regular crappy sky feed/ breakup issue. This happens on my PC/ DVI and Component from my DVD player. I guess the showstopper was when it started crashing without anything hooked up to it all together.
  5. jonathan
    jonathan
    Feb 8, 2002
    160
    19
    Kent
    Will keep you posted as to whether it gets any worse.
  6. RossallB
    RossallB
    Dec 11, 2004
    90
    This happens to me on my HD50, seems to be when the room is hotter than normal. I am sure its an overheating problem, have contacted Sagem about it but as yet, not found or got a solution, not happy about it at all.
  7. gtione
    gtione
    Aug 20, 2005
    London
    +3
    Sorry to hear about that, how long have you had you set?
