frozen Panny digibox......help!
Discussion in 'Satellite TV, Sky TV & FreeSat' started by MarTTy, Jun 11, 2002.
  1. MarTTy
    MarTTy
    Jun 10, 2002
    34
    Help..My Panasonic Sky Digibox has frozen on standby and after trying to reset I am still locked-out. Does anyone have a solution to this, rather than pay £60 call out to Sky.
    Martty
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,720
    2
    In a secret location with Jennifer Lawrence
    +10,720
    I don't want to suggest a load of things that you have already tried.
    so could you tell me what you have already done to reset it?
    Greg
  3. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    Unplug it, leave it for a min or so and plug it back in. It may take a couple of mins to boot up properly.
  4. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    i have a panasonic box that is exactly the same .
    it went into standby on it's own and won't come out .
    i was talking to the sky bloke when he fited my sky+. he said that the panasonic boxes have a dodgy chip and quite a few of them have done this exact thing . his advise was to go to a sat repair shop ( do not go through sky ) he said that it should'nt realy cost much above around 15 quid . sky will charge you 60 and most prob give you an old recon box . if i know sky it will be a first gen pace
  5. Doubledoom
    Doubledoom
    Make sure it is connected to the telephone line. Then turn the digibox power off at the plug for 10 seconds and then turn it back on again. Give it 10 minutes and it should come back on (unless it is a hardware fault).
    The above method has worked on at least 3 frozen digiboxes.
  6. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    ....including mine so make that 4 ;) Give it a try and let us know if it works :)
    Kelvin :D
