Frount and center speaker upgrade.....
Discussion in 'Home Cinema Speakers' started by jonnyv, Apr 30, 2002.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,320
    48
    +59
    I have mission 701 frount speakers :
    Model 701 Specification
    Acoustic Loading 2 Way Reflex
    Frequency Response 58Hz-20kHz
    Sensitivity 89 dB
    Cross-Over Frequency 4 kHz
    Volume 18.25 Litres
    Impedance 8 Ohms
    Recommended Amplifier 25 - 100 W/Ch
    Dimensions (mm) : Height 450
    Width 215
    Depth 300
    Finish Black Ash
    and a mission 70c2 center speaker :
    Model 70c2 Specification
    Acoustic Loading 2-Way Reflex
    L.F. Unit 130mm profiled glass composite cone, fully shielded
    Cross-over frquency 4kHz
    Frequency Response 55Hz - 20kHz
    Effective volume 16.85 litres
    Nominal Impeadance 8 Ohms
    Recommended amplifier power 25 - 100 W
    Dimensions (mm) : Height 200
    Width 502
    Depth 240
    Finish Black
    I am looking to upgrade these speakers for something better..probably from richersounds...
    I am happy with all the speakers but wonder if i can get better sound from a new set..
    any suggestions.....
    cheers
  2. Jase
    Jase
    Mar 16, 2001
    10,804
    United Kingdom
    +2,693
    The only thing I can suggest is to trundle along to Richer sounds and demo various speakers. Only you can decide if its worth upgrading.
    Personally, I´d be looking along the lines of the new Kef Q range or the B&W ranges. Kefs new Q1´s are supposed to be excellent as are the B&W S3´s. But it all depends on how much you want to spend.
    Demo, demo, demo!!:)
  3. lmccauley
    lmccauley
    Oct 24, 2000
    3,560
    Newcastle
    +343
    You can certainly get a better sound from a new set of speakers - the question is: how deep are your pockets? :D
    Cheers,
    Liam
