Fronts/Center/Rears?
Discussion in 'Home Cinema Speakers' started by weyland-yutani, Sep 9, 2003.
  1. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    I take it from most peoples set-ups that its important to match the fronts and center, but that you can use another manufacturer for the rears, yes?
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    Hi Weyland
    Yes to your question it isnt as important to match the rear speakers to the fronts most of the time.When playing multi channel music it does seem more important that they do match thats from what ive read.
    Gonzo.
  3. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    its not as important. but if you could i would.
    The difference when i matched my rears to the fronts after having missions was very noticable.
    The sound seems to move from font to back more smoothly and there were no gapps in the sound.
  4. Smurfin
    Smurfin
    Aug 13, 2002
    21,421
    +4,353
    Ian J said the same of his setup....a startling difference apparently, so it is important (but not quite as important as the front 3)
