Question Front Surround Placement - Limited Options, Which Would Work Best?
rsian
Am looking at placement options for slim wall mounted front surround speakers, but due to layout, not sure which would be best:
Three smaller LCR
Larger LCR all below TV
LR on sides of TV but would be 35cm behind centre. TV wall being built out a little meaning edges of speakers would be sitting within 5cm of TV wall - would this throw the direction of sound off?
All below TV, but centre sitting higher up
If I went for tall floor standing LR speaker, they would sit at roughly the same height as the speakers on the fireplace but a little bit wider apart.
A passive LCR soundbar under the TV would be the only other workable solution.
Appreciate any advice.
rsian
So either L&R slim mounted either side of fireplace, or L&R free standing slighter wider that the mounted option?
L&R mounting either side of TV - too far back, too close to wall, too high up?
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
