Front speaker problem with Yamaha RX-V4600
P
pinni1
for some reason the front L & R speaker connections have stopped working on my Yam 4600. All was working fine and then suddenly they have stopped. I have a neutron connection (from sub) connected (I have tried disconnecting and it doesn't make any difference). I have tested speakers and the cables and it is definitely not these. Has anybody else had this problem or can someone shed any light on this.
huntere
Sounds daft but I fell for this one after much ranting and raving......
Lil lady did the dusting and knocked the speaker A/B switch so lost L & R! Last thing I looked for! Not sure if same on 4600 but worth a look!
P
pinni1
Thanks for that mate, worked a treat! Obvious but somehow I missed it!
