Quantcast
Front poistion
Anrasp
I have my Mission M74i spread around 10 ft apart in the corner of my sitting room. Should the speakers be turned 45 degrees so that they point towards the centre of the room or should they be kept perpendicular to the wall ?
Zone
Why not try them both ways and leave them in the position that sounds best to you.
Mine are toed in to the listening position, some people have them facing straight ahead or toed in so as the sound fields would cross just in front of the listener, at the end of the day you need to experiment and see which method gives the best results for you using your equipment in your room.
