front main speakers
Discussion in 'Home Cinema Speakers' started by Peter O Sullivan, Apr 4, 2001.
  1. Peter O Sullivan
    Peter O Sullivan
    Just new to this site but hopefully can get some help.
    I have currently a Sony STR-DB830 amp which powers my new Paradigm CC-350 centre speaker (175watts) and new Monitor Audio Bronze 2(100 watts) speaker that I use as rears.
    My problem is that i need to replace my 2 front speakers (curently old 70 watt pioneer speaker from a old pro logic hifi) with something that can chuck out a fair bit of bass (has to take the place of a sub) and is still decent to listen to. I dont have the money at the moment to get a sub. The only thing is that they have to be bookshelf and not floorstanding speakers. Would be grateful of any recommendations keeping in mind the price
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Can't give a specific recommendation but you should match your front and center speaker to maintain tonal balance, ie they should be of the same make and series.
